Steering Box That Lasts
@Stude4x4 that's not a bad price, you can check out what the install looks like there;
http://dodgetrucksxtreme.com/forum/i...8853#msg158853
Ok, so I called redhead today and its $250 for a rebuilt box, plus $85 core charge. I found the AGR box on Summit for $370. I'm not sure which route i'm going to go yet. I'm also going to look into rebuilding it myself. I just need to find the parts and see how much they cost.
I have the Borgeson Dodge Box with the Borgeson steering shaft....works great.....the only issue I have had is the part that goes into the cab from the rag joint, its getting loose.
I need to do something soon. I might try and rebuild it myself, to save on money for now and just because I like doing stuff like that. If I had the money though I think I would buy the AGR box. I would do the crossover, but its a lot of work. Not that I can't handle it, but I don't have the time and can't have it down long. I just got married and am trying to buy a house, so the truck isn't top on the list. I'll post back up when I fix it. Thanks again.
Jake
Jake
I got mine from these guys about two years ago....
http://www.steerandgear.com/
I got the 3 1/3 turn lock to lock as opposed to the 4 1/4 lock to lock stock unit. So far its been rock solid, very tight and no leaks. This box along with a Borgeson steering shaft made a huge difference. I can't remember but I think I ended up with about $500 in the box and the shaft.
I have a AGR and not sure what they do if anything that's different from a regular rebuilt. I got it 3 years ago and it's shot!! The whole front end was rebuilt and now I find that the box is wasted.. near dangerous!!
No matter what your getting a rebuild. Cardone is one of the largest rebuilders in the country used to sell them new auto parts that they used for specs!!
I thought years ago I heard that chevy made a van in `87 or `88 that had a steer box that fit our trucks that was a 12:1 box??
I've got the RedHead box, and after a year or so, no problems, no leaks. Had an AGR, pos from the start. Leaked within a month, sent it back (under warranty, at my expense, $$$), still weeped oil, then turned into a major hemorrage. Within a year, more slop than one it replaced-never again. Not sure of warranty on other boxes, but AGR only had 90 days, (at the time, at least). Also have used the NAPA rebuilts, OK, but always had a lot of play (to me). Keep in mind, I've owned this truck since '92, so I've tried a few different pieces, and know what works, and what doesn't.
Just my .02
Just my .02
caver77
17
09-28-2010 09:27 PM
04ctd
10-05-2006 08:27 PM
unioncreek
06-29-2005 02:00 PM
Mark Craig
88
07-22-2004 10:37 AM
