starwheel
starwheel
well the other night i decided to turn the pump up ,it went all right till i started turning the starwheel i got it to an1/8 turn then i couldnt get it to go any futher in the process i also maneged to screw the starwheel up too any help would great thanks
Leave it alone?
It sounds like it was set pretty low to begin with and now you've got it jammed down at the bottom. It won't hurt anything until you get big injectors.
When I went to turn the starwheel down it only clciked twice and wouldn't budge. I didn't want to try and turn it any more because it seemed like I was going to damage the starwheel (guess I was right). The only thing I can assume is that it had already been turned almost to the bottom. I just left it. I think the starwheel just acts as a "false" bottom that you can raise up and down to limit the ride of the fuel pin. Don't think a few mashed teeth will cause a problem. We'll let the "guru's" weight in and both learn something most likely.
the starwheel adjusts the tension of the spring that the fuel pin/cone rides on. turning the starwheel down (clockwise) decreases the tension and up (counter-clockwise) will increase tension. it's an adjustment for more low-boost fueling. with stock injectors you can run it down and couple turns or to the bottom and not smoke too bad but once you upgrade to larger injectors, you'll want to run the starwheel up. the injectors will increase the low-boost fueling for you.
ok i turned my fuel pin to the deep setting [its stock] and i also turned the smoke screw in two turns with the starwheel turned all the way down when i start it up it dosent haze as much as it used to , with the pump set the way it was before i went in the pump it hazed a good bit on start up , now it dosent haze so much it actully took most of the haze away , i thought id smoke like a fraight train why dosent ?
Richard William
12-04-2004 11:44 PM
cummingetit
16
05-17-2003 03:38 PM
