starter solenoid
Old 06-01-2004 | 08:00 PM
92extle's Avatar
starter solenoid
Hey guys. My solenoid has become intermitent in the last two to three weeks. Just a click. If I pop to hood and lightly tap the solenoid it will fire right up. The starter motor itself seems fine. Going to pull it and clean everything. Does anyone have part #'s for brushes and contacts? Are they available through a Cummins dealer or aftermarket? Thanks.
Old 06-02-2004 | 12:01 AM
AlK's Avatar
AlK
Larry Buck carries the parts that you are looking for.
http://www.turbodieselregister.com/c...uery=retrieval
Old 06-02-2004 | 07:24 AM
Monty's Avatar
I had the same problem but caught it before everything got real bad in there. All mine took was a good cleaning of the contacts and some dieletric grease. If this doesnt work, like AIK mentioned, go with Larry B's starter contacts. They are better than stock.
Old 06-05-2004 | 01:28 PM
92extle's Avatar
UPDATE- pulled the starter this morning. Cleaned the contacts and plunger with a file to even everything up. Re-installed and all is well after a dozen starts. Looked like the original unit; had a Chrysler sticker on it. Also looked like the contacts in Larry Buck's picture. About a half inch wide.
dodgediesel
04-15-2010 09:00 PM
CRE2004
10-21-2005 08:05 PM
wannadiesel
06-27-2004 08:20 AM
JMZ
04-19-2004 07:57 PM
Quick Reply: starter solenoid
