stalled out and wont start
Well this morning I went out to start the truck.( I just got back yesterday for MN and being gone a week driving the truck straght 2500 miles around no proublems on trip) Well it started fine and I was letting it warm up snce I did no plug it init was only 22 last night. Well while it was idiling heard it go down like it was going to die so I hoped in and gave it some gas. then I pulled it out of the drive and down the street and stop at stop sign and it die. It sounds like it is out of fuel but it has a half of a tank. Where do I start the fuel pump in tank, the one on the block were do I start to try to find my proublem it has been a good truck and I need it running by this week end need to go t mountains to play Thanks please help speedy
well I replaced the furl filter and still nothing the fuel in the old one looked good and no gelling, I filled the new with ne fuel and nothing. I tryed the lift pump to prime it but i ge no pressure on the lever. I turn the motor over to different spots and try the pump and still no pressure on the lever, It is like it does nothing. How do I test a lift pump please help
Before you throw a lift pump at it, use an air hose and a shop rag in the filler neck to (very lightly) pressurize the fuel tank. We are not pressure testing it - we just want a little positive pressure in there. This will show up any leaks between the tank and the lift pump. It could be as simple as a rusty fuel line or a cracked hose.
To test the lift pump independent of the fuel system, put a short piece of hose on the inlet side of the pump and drop the free end in a coffee can of fuel. Open the bleed screw and pump the primer lever. If you get non-foamy fuel after a couple strokes the pump is working.
well I checked the fuel shut off wire looked good, so then i took off the line out of the lift pump were the fuel would come out of on top and turned it over and I did not get no fuel out of it. so that would mean that the lift pump it the proublem right. help please
Check the fuel lines for air leaks as I suggested above.
That's free, a lift pump costs money. If the lines are good and the lift pump won't pull fuel from a can of diesel, then the lift pump is bad.
well i tryed the lines and the can of fuel nothng so i took it off. this is what i found the lever that rides on the cam is not connected to the plungger any more some how it can on done and i dont see a way to hook it back up so itlooks like i need a new one, thanks for all the help now i get to have fun and bleed the ar out of the system fun fun
crash4wd
12-17-2007 08:44 PM
