speedometer quiet working
hello guys my speedometer was working fine when i turned my truck off when i cranked it back up the speedometer wouldnt work like it is a loose wire where do i look any info would be grateful thank you
the connection their is good it is a loose conection somewhere im sure didnt know good plaqce to start but just jump in any info would be great thanks guys
I believe that from the VSS, one of the wires (the 20ga. white with orange tracer) runs all the way up to the 6-way connector that plugs into the back of the gauge cluster. I'm not sure where the other wire goes but if you have a FSM, you could look in the wiring diagrams to find out. You could check the 6-way connector behind the gauge cluster as well and at least, if nothing else, eliminate that.
Here's how I took care of my speedometer for good.
https://www.dieseltruckresource.com/...x-t295107.html
Mosh
14
05-28-2006 06:41 AM
mytrucksaslug
05-26-2006 10:00 AM
landscaper
02-16-2005 04:21 PM
