Speedometer
Old 10-05-2022 | 04:26 PM
Jonesky's Avatar
Speedometer
Howdy. I’ve got a 1990 2wd Cummins with 3 speed auto. I don’t drive it’s often but have noticed the speedo recently seems to underestimate my speed. I downloaded a speed app for my iPhone and confirmed it. It’s reading slow. What should I check? I keep it tip top so want to fix it. Thanks
Old 10-06-2022 | 08:38 AM
Jonesky's Avatar
I’ll just try the vss…you know the thread 10 below mine.
Old 10-06-2022 | 09:02 AM
There are different gears for the VSS for the different gear ratios ordered on these trucks.
Different sized tires will also throw off the speedo.
How off is it at a given speed? 5 MPH off at 50.....more? less?
nothingbutdarts (10-21-2022)
Old 10-06-2022 | 09:50 AM
Jonesky's Avatar
Thanks Oliver. It’s significantly off. Like 20 mph at 50. Reads low
Old 10-06-2022 | 09:51 AM
Jonesky's Avatar
And tires are very close to oem. 2wd
Old 10-06-2022 | 10:54 AM
Jonesky's Avatar
I’ve got those speed sensors located on rockauto. I’ll give one a shot
Old 10-06-2022 | 11:14 AM
u2slow's Avatar
Does this change coincide with other work being done? Many dodges had an inline ratio adapter with the vss.
https://www.texasindustrialelectric....er_Adapter.asp
Old 10-06-2022 | 03:01 PM
edwinsmith's Avatar
When I got my truck the speedometer didn't work. It is an 89 with the old cable style. After some investigation I discovered that a reverse reducing gear was missing. Luckily I was able to find one and it fixed the issue. The odometer was running backwards!
Edwin
Old 10-06-2022 | 09:35 PM
Jonesky's Avatar
Thanks u2 and all. I have to get under there and look at it. I’ll report back
Old 10-21-2022 | 08:56 AM
Jonesky's Avatar
Ok, got down here and crawled under and replaced vss sensor with no fix. Still reading about half speed. Any further thoughts?
Old 10-21-2022 | 08:58 AM
Jonesky's Avatar
this is what I replaced
Old 10-21-2022 | 10:33 AM
u2slow's Avatar
That's the part that generates the signal.
There should be a ratio adapter ahead of it.
Old 10-21-2022 | 08:52 PM
Jonesky's Avatar
what would that look like? I will check and see if it ever had one
Old 10-21-2022 | 10:20 PM
u2slow's Avatar
This sort of thing
https://recordtechnologies.com/products/ratio-adapter
Old 10-22-2022 | 04:28 AM
nonrev's Avatar
My 91.5 D250 didn't have one of those either and the speedo worked fine
Quick Reply: Speedometer
