Some one want to give me a history lesson
Old 08-16-2010 | 12:11 AM
kellypckp's Avatar
Type of pumps and years they were put on?
Turbo and years they were put on?
Just wanting to know a little history of my beloved trucks if you can help a slow man that would be great!
Old 08-16-2010 | 12:41 AM
simplysmn's Avatar
Hey kelly how's the crew ? going you still have it ? as for your question I believe the ve pump was on till 97? not sure on turbo size I believe the non inner cooled truck's have a bigger turbo ?Don't quote me on that thou .
Val
Old 08-16-2010 | 01:24 AM
CONFEDERATESON's Avatar
89-93 was the ve pump. 94-98.5 was the p-pump. 99-02 was the vp44 and 03-present is the cp3. 89-93 the turbos are all h1c's but some had diff exhaust houseings. second gen they used the hx35 and 40. third gens are the he351cw and another vareation of the 351 i believe, dont remember what it was called. pretty sure this is right if not someone will correct me and and fill in what i missed.
Old 08-16-2010 | 01:43 AM
89-91= Bosch VE Pump...... H1C turbo's. 89-91 had 18.5cm exh. housings, 91.5-92 had 21cm housings, 93 went back to 18.5cm housing
94-98= Bosch P7100 Injection Pump...... 94 was the WH1C turbo w/12cm housing. 95-98 is the HX35 w/12cm housing. (some 95's still have a WH1C, most i've seen have the HX35)
98.5-02= Bosch VP44 pump (electronic)........01-02 Automatic trucks had the HY35 turbo w/9cm housing, 98.5-99 Auto trucks and all 98.5-02 manual trans trucks had the HX35 w/12cm housing.
03-04= Bosch CP3 Injection pump........Holset HE341cw turbo
04.5-07 (HO 5.9L)= Bosch CP3 pump.......Holset HE351cw turbo w/9cm housing
07.5-Present 6.7L= Bosch CP3 Pump.......Holset HE351ve turbo (sometimes know as VGT, Variable geometry turbine)
Old 08-16-2010 | 06:39 AM
KD93's Avatar
98.5-02= Bosch VP44 pump (electronic)........Automatic trucks had the HY35 turbo w/9cm housing, 5 speed and 6 speed manual trucks had the HX35 w/12cm housing.
There he is folks, DTR's very own Wikipedia! I bet you didn't even have to think about it either. Wish I had a memory like that!
Old 08-16-2010 | 12:39 PM
jimbo486's Avatar
In addition to Brandon's post, '89-'91 h1c's, aka the baby h1c's, also have a 50mm comp. wheel. The '91.5-'93 h1c's have a 54mm (?) comp. wheel.
Old 08-16-2010 | 01:36 PM
raggmann's Avatar
Very good info Crossy's.
Now the question is-which turbo would I want to replace the one on my '93?
I've read all the talk of this number,that number etc. I just want to know what donor I'm looking for to rob the turbo off toput onto my '93 to get the EGT's down a little.
Old 08-16-2010 | 01:40 PM
scottsjeeprolet's Avatar
My 99 auto has the factory HX35.
Old 08-16-2010 | 02:09 PM
hvaccer's Avatar
That's because the automatics didn't get the HY-35 9cm until 01 model year. 98.5- 2000 were all the HX 35 12cm.
Old 08-16-2010 | 08:38 PM
Interesting, Didn't know that.
Fixed my post.
Old 08-16-2010 | 08:40 PM
HE351CW is a great turbo. 04.5-07 (5.9)
Old 08-16-2010 | 09:57 PM
raggmann's Avatar
Thanks son,just what I needed.
With all the numbers out there I was gettin' bad confused trying to figure out what "donor" I'd need.
You've cleared that big ol' mess I call a mind up.
Thanks,
Old 08-16-2010 | 10:33 PM
dzl_damon's Avatar
Agreed, but not simply a bolt on process. There are several (albeit relatively easy) things to do to get the HE351cw on:
A.) 4" Downpipe with a flat faced, 4" inlet to the DP
B.) Drill out 2 bottom flanged holes on the HE351 (they are tapped, just drill out same size as top ones
C.) Remove turbine and compressor housings, grind a little alignment pin on the exhaust side, and clocking (rotating) the housings so they match the stock H1C.
D.) Finagle your intercooler piping slightly since the elbow off the compressor is not out as far as the stock H1C's clamped on discharge elbow
-or, leave the elbow straight up in the air, and make a whole new intercooler piping, eliminating problem E.
E.) Figure another way to use the wastegate since with a clocked compressor housing, the wastegate has no mount. A simple heavy spring pulling on the wastegate will work, and the gate will open now with exhaust pressure.
F.) Longer studs for the turbo flange would be nice, mine luckily came with 2 and I oddly had 2 more off an Hy35 I had kicking around.
Any turbo removed should get a new turbo flange gasket (about $5) and a new oil return gasket.
Hx35 will be BOLT on, except maybe the turbo outlet? Flows better than the H1C, but not a drastic improvement (I'm told).
Old 08-16-2010 | 11:47 PM
schamran's Avatar
I believe Jack Roush was the first to put a Cummins in a Dodge. There's some history for ya.
Side note: Jack Roush crash landed his plane at EAA Oshkosh airshow in Oshkosh Wisconsin a few weeks ago. He walked out of his plane, even though he lost his eye! Oshkosh is less than an hour from me. Only reason I know this. lol
Back on topic.
Old 08-17-2010 | 01:24 PM
DevilzTower's Avatar
What's the exhaust housing cm on the HE351CW?
i.e. - 12cm?
