Solution For Fusible Links !!!
I just found this :
http://www.delcity.net/delcity/servl...=790097&page=1
: I think I will start systematically killing fusible-links and replacing with these.
what i did on my truck was put everything on self resetting breakers. that way i dont have to carry fuses with me. might be bad, might be good. i'm not sure sure was more expensive than what i thought, but once i started i couldn't bring myself to stop
Oh just great.
I've not even relayed the headlights yet and you throw this at me.
Still gotta KDP too..
List just keeps getting longer...
This will help clean up that fender area, and maybe help stop some of those electrical grimlins at the same time...
Just did mine a couple weeks ago no problems since, also found a wire in that big wire bundle shorted to ground when wire bundle bounced around on the fender. This wire was hot all the time through the ignition wire causing the truck not to start, shorting shut off valve for fuel, and a killing my battery dead problem. Worth taking a look at and change over to CB's.
