simple little fix
Old 01-22-2008 | 11:03 PM
JBOND's Avatar
simple little fix
djust thought id share a simple fix for loose heater/ac dash inserts. several of mine were loose in the hole and one kept wanting to fall in the dash but it wasnt broken. i took them out and put them in a pan of boiling water for about 30 sec or so. then i carefully pryed the little tabs open and propped them open with a tooth pick them put them back in the boiling water for about 10-15 seconds. then i just took them out and let them cool and removed the toothpicks. put them back in the dash nice tight fit. this worked so slick i just thought id pass it along.
Old 01-22-2008 | 11:20 PM
91.5 beater's Avatar
good idea i have the same problem and have stuffed cardboard between the vent and the dash to hold them ill have to do this thanks for the suggestion.
Old 01-22-2008 | 11:43 PM
JBOND's Avatar
yep i had cardboard or folded paper stuffed in them too
Old 01-23-2008 | 12:51 AM
BearKiller's Avatar
That is some real good advice there and should possibly be "sticky" material.
I doubt there is a 1st Gen. truck on this forum that isn't plagued with at least one loose vent.
Old 01-23-2008 | 06:30 AM
Here's what I did: Popped the vents out and put a strip of the "fluffy side" of velcro on the top and bottom. From the factory they had felt strips there, but those fell off most of out trucks about 5 years ago.
Old 01-23-2008 | 10:12 AM
leper's Avatar
OMG, that is exactly what I did.
Old 01-23-2008 | 04:30 PM
JBOND's Avatar
i have to admit the velcro fix is probably easier but but then you wouldnt get to boil car parts on your wifes kitchen stove. he he he
Dodgezilla
18
10-11-2014 09:03 PM
Dodgeboy3196
11-13-2009 07:57 AM
Dangousity
04-06-2007 06:48 PM
somis13
01-11-2007 04:40 PM
