Shut off solenoid replacement
Can I put a normally closed solenoid valve on the fuel line going to the injection pump? Then I could chunk my worthless shut down solenoid and plumb in an extra fuel line!
With a normally closed valve when you shut it down its going to starve the IP, it probably wont die instantly. When the fuel in the IP is used it will die. Problem I see is loss of lubrication when IP is starved.
Dave why in the world would you agree with him ? We are never going to hear the end of this, your an admin, go delete that quick.
Doesn't the pump starve just almost as much with the stock solenoid?
skywalker175
05-13-2003 02:37 PM
