Short-Style Bolt-In 14cm Housings!!
I found a local diesel performance shop today that sells custom 14cm non-wastegated housings that bolt in with no exhaust mods. They take a stock 14cm housing and cut the back off (and maybe machine it) to make it the same length as a 16cm/18cm/21cm.
With the new 4" exhaust I don't have much room to work with and wasn't looking forward to cramming a long-style 14cm housing in there.
This was just the answer! ![guitarist](https://www.dieseltruckresource.com/forums/images/smilies/guitarist.gif)
If anyone wants one, give Mark (I think) at Gillett Diesel Service a call. Mods, please feel free to edit/delete if this is not acceptable.
![Dummy!](https://www.dieseltruckresource.com/forums/images/smilies/new1/smashfreakB.gif)
Last edited by wannadiesel; 06-23-2006 at 07:15 PM. Reason: pricing and phone # removed
Originally Posted by bgilbert
JMO, but I would want a wastegated housing if I went smaller than 16cm.
With the 14cm housing and 4" exhaust my EGT's only dropped maybe 50*.
I don't get it. Stock injectors and just under 2 turns on my fuel screw and I still have high EGT's, even with the Stage III hybrid and other mods.
![Confused](https://www.dieseltruckresource.com/forums/images/smilies/confused.gif)
![Mad!](https://www.dieseltruckresource.com/forums/images/smilies/new1/madani.gif)
Patron Saint of 1st gens
I strongly agree with bgilbert regarding the use off wastegate on the 14cm and the 12cm housings. They are pretty small and it doesn't take long before the begin to have some pretty nasty drive pressure, a big jump in boost air temperature which in turn will cause significantly higher EGT's.
This is something you obviously want to avoid whenever/wherever you can.
If you use the WG to control max boost levelss you'll find that the smaller housing will help alot and also lower the high temp charge air going into the manifold.
pb...
pb...
I don't get it. Stock injectors and just under 2 turns on my fuel screw and I still have high EGT's, even with the Stage III hybrid and other mods.![Mad!](https://www.dieseltruckresource.com/forums/images/smilies/new1/madani.gif)
So even with a current max boost of 34psi I should still have a wastegated housing? I hear of people running the same hybrid turbo up to 45psi with a WG housing. Wouldn't 45psi with a WG be a lot worse than 34psi with no WG? I figured with a WG I would still want the full 34psi of boost I have now, so how would a WG help me?
At what boost psi can the drive pressures expect to become a problem with a 14cm housing?
Wanna, I'm at about 5,000' of elevation. The timing was already bumped when I went in to do it. There is just a hair under 1/8" between the two marks. Could I possibly still be timed at the default factory timing if those marks aren't lined up?
I don't think you need a wastegate yet, 34 psi is not excessive. Adding some timing will lower the boost some, too. 45 psi would be just heating the air, I would not run over 40 psi.
At a mile high it is hard to keep EGT down even on a stock truck. I really think a 12 cm wastegated would be a better housing for you.
Without actually checking the timing there's no way to know for sure where you're at, but it won't hurt to bump it up a little and see if it helps and doesn't sound too harsh.
Thanks, Wanna. That's kinda what I figured, but Bill and Bob scared me a little.
What does it usually cost to have a shop check the timing (and adjust if needed)? I don't really want to get into it myself, but I don't want to be overcharged either.
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
![No No](https://www.dieseltruckresource.com/forums/images/smilies/new1/nono.gif)
It shouldn't cost much if you can find a shop that still has the tools to do it. Tell them you want 1.6 mm lift, that's about the max stock injectors should run.
Oh, when doing the timing how on earth do you get to that top bolt near the head? I bought the set of S-wrenches from Harbor Freight, but still can't get to that darn bolt.
