Shift light
1st Generation Admin
Be careful using the TV to adjust shift-points as the TV also adjusts hydraulic pressure to the clutch-pacs, etc. Too loose, and you may slip a clutch if the pressures aren't high enough to accommodate your power level.
Thanks for the advice. My problem really is that where I have the tv cable set now the 1-2 shift happens at 3000 and the 2-3 shift happens at 2500. I need to turn up the line pressure some in the trans and figure out how to move the 2-3 shift to 3000 also. Then I can back off the tv cable to shift at 2700-2800 then I would be happy. But I don't know how to adjust the shift points seperately from one another.
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
MoparRiggan
29
11-09-2008 12:02 AM
CASMOKIN
Competition / Pulls / OffRoad
12-30-2005 01:28 PM
