which sensor controls speedo?
My speedo has been reading very low at times, then will spike right up to my actual speed-never goes over. I checked the trans and found that mine has 2 wires that goto a sensor. Does this control speed? And the rear diff sensor then covers RWAL?
the sensor in the rear diff is only for the ARWAL or anti-lock brakes!
CS.. the connector tends to get corrosion in it , so a good dab of electical grease in teh female side before you reconnect it will help assure a good contact. Also check the gear reducer and generator to make sure they are snug, they can work loose.
I did check them I yesterday-a hair tightening was all. I remove the sensor and take a look, grease her up and see what I have. I noticed that a new sensor isnt the cheapest
Bradleysram
19
05-12-2009 08:36 AM
TexasHardcore
05-17-2005 09:03 PM
