rusting floor pans
rusting floor pans
This past fall I noticed the carpet wet in the truck. So I started looking for areas for water to get in side and found both cowls leak, rear window and condensation from the a/c heat exchanger. So I pulled carpet and all the sound blanket and found a good bit of surface rust. Every one might want to check on this. I felt that my truck was in great shape and I should not worry. (Besides, nothing has ever been hauled in the bed.) I sanded, primered and put a can of bed coating on both floor pans. Turned out good, bought the Dupli-color brand and one can did both pans. Picts attached.
Where is the best place to get replacement parts?
When I bought my truck new in 91, I knew carpeting and farm mud
don't get along. I pulled the carpet and stored it away, then I had the whole cab floor covered in spray on bedliner. easy to clean and no rust issues.
Off topic............
91.5CTDBanks,
This Mopar has rusty floors too. In fact it's pretty rough.
http://www.worldofwheelz.web.aplus.n...y/DSC00028.jpg
Car:
http://cgi.ebay.com/ebaymotors/ws/eB...062&rd=1#Photo
Car:
Carpet has no place in a truck. They should all have rubber floor mats.
91.5CTDBanks,
Car:
Car:
Good job on the floor repair! I hate to see what's under the carpet on my 93 My 70 Bronco was rusted pretty bad under the front carpet, and it was even an AZ rig
I have wet carpet too, and i've started to worry about the potential for rust. the truck came from the dry side of the mountains so it hasn't been wet for all of it's life anyway.
But where did you find the water leaking in from? How did you fix the leak?
I like the bedliner idea the best..My 77 M880 had plain steel floor with rubber mats, very nice. Will it get much noisier if I skip the carpet altogether?
