RPM Gauge
Old 06-10-2007 | 09:41 PM
Power Ram 250 C's Avatar
When you guys hooked your isspro tachs up to the factory plug, what wires went where? Thanks.
Old 06-10-2007 | 10:47 PM
GasganoFJ60's Avatar
Originally Posted by Ace
They're definitely not the same ones. I'd vote ISSPRO's for best. The one I have uses a crank sensor for the pickup, no calibration required, rock steady and accurate.
Which model Isspro tach do you have? Im getting really close to purchasing one.
Old 06-11-2007 | 06:56 AM
I have a 2 1/16" tach model R-1640.
Old 06-11-2007 | 05:36 PM
Ok. All this being said, which is the best route? Using the facotry wire harness and using the Isspro hardware? Or it it just as good to run out to the parts store and get an alternator driven tach?
Old 06-12-2007 | 09:59 PM
The factory wire harness would be the easiest route, if you have one.
Old 06-19-2007 | 03:33 PM
74dart's Avatar
What brand name is the tach. Also looking for a full pillar triple pod for the gen 1 dodge where can I get one?
Old 06-19-2007 | 04:30 PM
gomerpile's Avatar
well i just installed a sunpro super tach II and set it to 4cyl and hooked it to the harness.works just fine, rock steady, and just 38.20 at autozone. if cheaps your thing
Old 06-20-2007 | 06:33 AM
I don't think they make a 3 pod pillar mount for the first gen dodges. I've heard of guys buying the dual pod and a single pod and mounting them together to get three in a row.
Old 06-20-2007 | 03:24 PM
taterfarm's Avatar
JC Whitnay sells a universal triple gauge pod.
Here is a link, the picture shows a dual pod but it is a triple.
http://www.jcwhitney.com/autoparts/P...?Ntt=pod+gauge
jefjsak
01-15-2015 03:44 PM
53 willys
31
01-31-2008 02:24 PM
skeeter
01-18-2006 03:17 PM
dieselnewbie
04-13-2004 12:00 AM
fishin fever
02-22-2004 08:32 PM
Quick Reply: RPM Gauge
