Rotors Pads and Drum Replacement
Hi guys,
It is getting to be time to replace my brake pads. I am thinking about putting all new rotors, pads and drums on my 89' D-250 because I am not sure when they were replaced last seeing as I bought the truck last August. I can tell already that the rotors are warped due to the jerking while applying the brakes. Does anybody have any recommendations for who has the best for the cost of any of the items listed above?
Unless it's untaxed, then it's red.
I just did pads, calipers, rotors, brake lines, and wheel seals all from rock auto. Total cost was around $350ish. There is a great thread in the stickey with exploded views of the locking hub innerds
You will need to press out and in the lugs if you chose to replace rotors, easy if you have a press, hard but possible if you don't.
Not all that hard if you have the right parts.
Good luck!
Good luck!
Both those places have their stuff renamed, but who really knows where it's made? If I were you, I'd look for Raybestos, Wagner, or Bendix, with Raybestos being my preferred choice. Why? 'Cause that's about all they do is brakes. Rockauto will be able to help you out.
Just my $0.02, and I'm sure others will have their favorites too.
LockedandLoaded
13
03-24-2008 12:16 AM
Mcmopar
05-11-2004 09:46 PM
