replacement fuel tank strap?
Went outside today and saw the rear of the fuel tank was hanging down. The fuel strap gave way but it didn't break it looks like it somehow came out of the slot? I don't like that setup but anyway, where does one get a replacement strap cause I'm sure the bolt is rusted to hell. How much $ am I looking at. Thanks, Matt
The problem isn't the strap, but the way it is hung.
Check this out:
https://www.dieseltruckresource.com/...d.php?t=173605
Look at the way the forward end mounts, then compare it to the aft mount; the forward mounting is much more secure.
Check this out:
My rear strap broke also. I used a piece of strap steel for most of it and then bolted a chain toward the inside to a bed crossmember. Works well and didnt cost that much to make. I also used some padding between the strap steel and the tank, to help elieviate(sp) and future rubbing from strap to tank.
