Replace Windshield Wiper Grommets, Question
Old 09-25-2009 | 12:56 AM
Santaclaus's Avatar
My windshield wipers quit working, the drive link fell off of the motor. I removed both put assemblies and drive linkage assembly replaced all four a little plastic grommets. Replaced everything turned on the wipers and a driver's wiper swings past the edge of the windshield, the passenger windshield wiper swings in its normal path. Any ideas what I did wrong? Of course I completed reassembled everything.
Mik
Old 09-25-2009 | 02:08 AM
sdstriper's Avatar
You can pull that wiper arm off the splined pivot shaft and reposition it very easily. There should be a release latch on the arm, you have to carefully pry it up off the splined shaft. Careful not to bust the windshield etc. Reposition it a few splines and try it. Move it a few more if needed.
Old 09-25-2009 | 02:09 AM
Ronny Bailey's Avatar
When they are off, is the driver's side higher than the other one? If it is, the wiper arm may need to be repositioned. I just went through this the other day. Here's the thread.
To get the arm off, you have to lift it away from the windshield and then swing that little tab to release it. If you're like me, you'll have to do it a few times to get it right.
Old 09-25-2009 | 09:26 AM
Santaclaus's Avatar
In the process I had removed both wiper spindles and reassembled everything outside of the vehicle, the spindles looked the same although I did not compare very closely nor do I mark right and left. I will call the Dodge Park House and see if they are different. The position of the arms in the park position is correct. It's just that the drivers wiper goes past the edge of the windshield, the park position for both is correct. I'm hoping is a difference in the spindles.
Mike
Old 09-25-2009 | 10:18 AM
Santaclaus's Avatar
I just called Dodge parts department and they tell me there is a left and a right spindle. Apparently I interchange them during a reassembly. Thanks the responses looks like I'll take it back apart and do it correctly.
Mike
TxDiesel007
05-19-2013 07:14 PM
Red3quarter
10-29-2012 10:22 PM
BC847
02-21-2012 11:21 PM
AggieJustin
11-22-2011 12:25 AM
red70ragtop
03-26-2006 02:47 PM
