Removing the VE44
I assume you mean the injection pump? Other than a steering wheel puller to pop the gear off, nothing special is needed. An "S" or "U" shaped 13 mm wrench is helpful on the bottom mounting nut.
Make sure you have engine at TDC and keyway on pump shaft straight down and use the U shaped washer to lock the pump, that way it will still be in time when you put it back.
w4xtc
24
05-05-2003 04:36 PM
pappyman
15
01-01-2003 12:23 PM
