Reman injectors with higher pop psi
My old injectors were down 900 psi ~ 2600.
The Cummins reman injectors I got pop tested around 3800-4000.
This is higher than stock as far as I know. Does this mean I need to advance the pump timing? If so, how much would ya'll think?
Thanks,
Brian
Thanks,
Brian
By the way, my interest in this truck (right now) is not more power. I want to be able to safely tow a 24' gooseneck with a 7000 lb. Kubota tractor on the freeway & up dirt roads without fearing it will blow up. When I get more time I may bomb the truck. Right now I want to buy farm equip. (backhoe, bush hog, box scraper, chipper) and build a cabin & pole barn. So, I'm somewhat concerned about advancing the timing too far.
Brian
Brian
04ctd
08-27-2012 06:47 PM
idracingcop
08-20-2006 08:31 PM
