Rear Axle Bolt Torque Specs
The FSM isn't clear, my friend is putting a D70 back together, and want's to know the torque specs....
1st Generation Admin
Model 60 & 70 Axle:
- Axle flange to hub bolts: 70ft/lbs.
- Bearing cap bolts: 70 ~ 90ft/lbs.
- Case half bolts (powr-lok): 65 ~ 70ft/lbs.
- Case half bolts heavy duty (powr-lok): 90 ~ 100ft/lbs.
- Diff cover bolts: 35ft/lbs.
- Fill hole plug: 25ft/lbs.
- Ring gear bolts (Grade 8): 100 ~ 120ft/lbs.
- Ring gear bolts (Grade 9): 125 ~ 135ft/lbs.
- RWAL brake sensor: 18ft/lbs.
The Burning Rom
06-23-2005 09:55 PM
