rbrettctd, some one calling BS on your mpg.
#31
I get 19 MPG with my 6 inch lifted, running on 37 inch tires, with 4.10 gears in my W-350 '85 crew cab with a getrag, '90 12v, that is bone stock.
My other 3.07 auto '90 12V AUTO '85 W-350 crew cab gets 21 MPG with 33 inch tires.
That is around town driving, with a "not trying to get good mileage" driving style.
Using a light foot, a VE pumped 12V, with a 5 speed and 3.07 gears, could get 25-27 MPG, this would be easier to do if it was a 2wd
#32
You guys don't even wanna know what my '90 is getting with 3.54, 235s, .73 OD gear (6th in NV5600) and being around 5700lbs. Something's going on because I can barely manage to squeeze 15mpg out of it!
#33
Unless it's untaxed, then it's red.
I managed to get 23 once I got my converter in. That made a huge difference. I also keep my tires up around 75 lbs.
I'm hoping the in town goes up soon once I finish up the the he351. Low end boost to match the VE low end grunt.
#34
Best I've seen with my crewcab running back from Oregon to BC was just shy of 28 MPG. But that was all hwy, and I was only bringing back the truck box I bought down there.
Around town I usually see about 20-21mpg.
I'm interested to see what my mileage goes to once I do the 4x4 conversion, since the diffs I have inthe donor 93 are 4.10's. If it sucks too bad then I will switch back to 3.54's.
#35
The best I ever get is 19 on the highway nursing it at 65mph.
How are you guys getting 23?
I know I've got big tires, but I figured I'd be doing better.
#36
I'm with you. I filled up today and did the math and i got 15.6. That's not uncommon for my around town. I just recently turned my pump up, and it's making way more power for sure, but I was hoping with more fuel earlier I would actually see an increase in MPG.
I regularly get 20-21mpg in the 89 2wd with a very tight transmission and 3.07's I've gotten 23mpg on occasion.
My best in the dually was about 18 or 19 when I first got it on stock tires and less tired transmission. I get about 15 with it now if I'm easy on it. Tires and transmission.
#37
You might check your odometer against the mile markers sometime you run a fair distance on the interstate. My speedometer runs about 9% behind actual miles.
#39
I agree, inaccuracies in the odometer would probably explain a portion of the claims of extreme mileage. I know this thread is from 2008, but the best part of any video or controversial article on the internet is the comment section. If someone posted a video on youtube of a baby being rescued someone would dislike it and post some a-hole comment...sort of like how message board works
#40
My speedomoter reads 5% slow, running a mile with the speedometer at 60 takes 57 seconds. And I've estimated my odometer shows 9% behind actual mileage.
#41
Alot of people don't understand that driving style affects mpg very much. In my Corolla i used to get 30-32mpg then I relaxed and changed my driving style and got 41mpg on a tank of gas, I was amazed that slower acceleration and keeping the RPMs below 3500 really changed the MPGs that much usually I get about 35-37mpg overall but if you really think about what you are doing you can get pretty decent mileage but people call BS on it because they haven't gotten it so its impossible.
#42
The most ACCURATE way to figure mileage is on a long trip using your GPS to measure mileage traveled. And even the GPS shorts you on mileage when you're on hills. That's what map mileage is always shorter than actual mileage travelled. Map mileage is figured as though all roads were flat! So NOBODY REALLY knows what their mpg is - there are just too many inaccurate variables..... even the gas pumps are inaccurate these days with no money to pay inspectors and pumps going years without inspection. My Audi TDI says it's getting 42 all around mpg and better than 50 on the highway. I don't know how far off that is, but even if it's optimistic by 10mpg, I wouldn't trade it for a dozen Priuses!
#43
Since " THEY " took the lead out of the gas ( I know diesel don't have lead) ,it seems to have went to someones "foot". Slower acel. on the peddle makes better mpg.
whosdunit.
whosdunit.
Dodgezilla
11-18-2006 05:29 PM
97CTD
02-24-2003 05:00 PM
