Rattlin driving me crazy
Old 05-23-2007, 07:46 PM
jjdiesel1990's Avatar
Hey guys,
i have this annoying rattling noise that just started about a month ago every tome i hit a bump. i've checked the exhaust, taken the loose tailgate off, checked every nut and bolt, the shocks and nothing seems to be loose. the shocks don't move when i pull on them, but they are 17 years old. could this be the noise or is it in the rearend?
thanks
Old 05-23-2007, 07:55 PM
rbrettctd's Avatar
It couldnt hurt your ride to replace the shocks. And one question for ya---How can you differentiate one rattle from 14 others?
okiesmartguy's Avatar
i dont knpw but mine has the same thing if you find it tell me i have done all the same things and more trying to find it
Old 05-23-2007, 08:00 PM
BRUISER's Avatar
hahahahha I had the same issue..
I found mine it was one of the bolts holding the 4x4 shifter in place..
Old 05-23-2007, 08:06 PM
bullfrog5.9's Avatar
check the little metal things on the claipers there like spring things they make noieses when they burn out
Old 05-23-2007, 08:10 PM
she got drums on da back
Old 05-23-2007, 10:54 PM
frmll300's Avatar
I take it you beleive the noise is coming from the rear of the truck.If it is in the front I would agree with bullfrog 5.9 ,he is refering to the front brakes . On my '90 one of those springs let go very shortly after newly installed.
Another thought is, do you still have the spare tire hanging under the truck ?
Do you have running boards with some loose mounts?
Old 05-24-2007, 12:42 PM
angelfire7's Avatar
Same rattle, ended up being the shackle bushings were shot on all four corners. Only rattled over bumps and other weird places in the road. Now the 4x4 shifter was a different story!
Old 05-24-2007, 04:47 PM
yeah, i should have mentioned it was coming from the back. the spare and all that crap is gone and it doesnt have running boards...its makin me mad
Old 05-27-2007, 07:48 AM
Cowboy_Customs's Avatar
Check the front anyway. Just before the accident I discovered the dust shields were rusted off and it is annoying as anything. ANY little bump n it sounded like the truck falling apart in million pieces. Also check your bed mounts. just give a good hearty tug on all 4 corners.
Old 05-27-2007, 08:04 AM
BearKiller's Avatar
Question Have You Looked Under The Seat ??
When I was a kid, I had an uncle to spend a fortune trying to eliminate a noise, only to find that two coke bottles were rolling around under the seat.
Old 09-02-2007, 07:05 PM
I finally found out today what the noise was. Now this REALLY makes me mad becuase its something I should have absolutely, unquestionalby seen immeadiately. But as I was driving down the highway, the grill fell off the front of the truck. Then I hit a bump and the noise was gone! The grill was shot anyways, so I'll just get a new one. Just had to let her fix herself.
Old 09-02-2007, 07:34 PM
Tron's Avatar
I thought you said it was from the back. I have over load springs and the rubbing blocks were worn out and the springs were hitting metal on metal.
Old 09-02-2007, 08:22 PM
RumbleFish's Avatar
should have been more specific...he meant while the truck was in reverse
Old 09-02-2007, 09:06 PM
rockfoot's Avatar
lol... you guys....
Quick Reply: Rattlin driving me crazy
