ram air for stock air box
Hi all... have been pouring over intake options for new to me truck. the smokey[and copys]look nice but the air sorce looks to be the factory duct and any extra warm engine compartment air...soooooooooooo what if using a k&n or greenie[read high flow filter of choice]in the stock box . and instead of swiss cheesing it for more warm air ,you get some ducting and snokels from the bone yard and you fabicate two cold air ducts picking air at bumper level or there abouts, then piping them into the stock box those plus factory inlet makes 3 all cold what ya think
Re: ram air for stock air box
Check out the pictures in my Picture Gallery, I have a cold ram air system I built using a Banks air scoop. Gives my FREE boost at freeway speeds. Not sure where you live but consider some way to prevent the injestion of water from puddles if your truck is low.
Here to help with any questions. Jim
Hey Jim Lane; now that's what I love about the DTR pose a problem get an answer ,pose an idea.....get it drawn out in pictures, plus the field trail results. I really like your idea of using existing inlet [less work].I never felt that there was anything wrong with stock box except air supply but this is just dodges way of making it sound more carlike just like the silence ring on hx35 .Anyway Jim 1 ques: one of your pictures mentioned.. note hole or cut in fender sheetmetal could you please explian futher heck of a good design Thanks [Victoria is on Vancover Island 20 miles across the water from Bellingham ,Washington] . PS thank-you also Mr Whitmore your design is excellent as well however I'll be mostly stock ,but for the guys running the big hp numbers they should take a looksee Eric
Ram Air
Yes if you look closely where the 4" duct drops down through the right inner fender I used a cutoff wheel and notched out a hole for clerance of the duct. I dressed the edge with a clip over type moulding on the edge so it would not buff a hole in the duct. The inlet assy. is sealed to the opening in the air box with aluminum foil tape used for HVAC also and a pop rivet or so. The 4" sheetmetal tube I used on the air box is standard HVAC air duct as is the end cap intended for it. The flex duct is the aluminized/ mylar kind used for common dryers and will not burn. I got the parts at Home Depot but any local HVAC parts store will have it. The air scoop I got was from Banks and is the one they used on the large motorhome ram air systems. I live a few miles from Banks Engineering and went browsing aroung the shop and displays and found what I needed, that part I think was about $25.00 or so. The entire outlay for the sheetmetal parts and duct was also about $25.00 maybe less. You can get creative and fabricate your own air scoop with maybe a 4" 90* bend, ABS would not rust and could be painted. Be a good idea to cut out a 2" hole at the back side of the scoop for a drain.
You need to be careful you do not injest water into your engine from a deep puddle and cause a hydrostatic lock in your engine. Let me know if you have any other questions.
Jim.
Ram Air
Originally posted by boiler-rat
Jim, how much difference did the ram air make in your boost?
The air scoop inlet area is approx. 4" X 6" and is directly in the air stream.
Also before I had it on, when I got on the throttle hard I could see a visable exhaust haze in the mirror but afterwards it is almost gone. So I am obviously increasing my fuel / air ratio.
Later Jim.L.
bigragu (11-01-2016)
Hood Scoop
Originally posted by 92DIESEL
Has anyone tried using a hood scoop? I think it would look cool especially with stacks.
Jim.
Hey Jim, thats what I've been wondering but I can't find any pics. Do you have any or know of any, I'm going to go with a BHAF soon but am undecided on if the stock location is the best. Colder is better- Right?
Thanks again,
Michael
Thanks again,
Michael
Hood Scoop
Long time ago in the old drag racing days I used to buy from A&A Fiberglass but a check on the computer and I cannot find them but I have found a few sites that have a good selection. There are some good pictures of the old mopar and ford style. Actually some of the cowel induction style I have seen on some Chevy's and I think one was a Syclone. After you get over the horror of cutting a hole in your RAM hood for the scoop all you would need would be a boxed in underside plate directly under the scoop to capture the air and then a bellow to duct it into your air box. This should be fairly simple sheetmetal work most people could handle. Think the cowl induction would look and perform outstanding especially if the front of the truck was dropped. Checkout these sites:
http://www.galebanks.com/im_moparnow_spring03.cfm
http://www.up22.com/
http://www.hotrodssuperstore.com/fibhoodscoop.html
http://www.fiberglass-hoods.com/hood-scoops.shtml
http://www.truckoutfitters.com/hoods.html
http://www.powertown.com/product.asp?id=26700
As I mentioned before, I am about 3 miles from Banks Engineering in Azusa and they have some awsome things at this place.
Jim L.
Jim L.
