Radiator Flush
Radiator Flush
I am going to have my thermostat changed tomorrow in my friends shop. Would you all go ahead and have the radiator flushed out? He has the machine there to do it properly. I am leaning towards going ahead and doing it. I am sure there is a bunch of crap in there after 200,000 miles. <br><br>Also would you all fill it back with a good quality antirfreeze/water mix or spend the extra bucks on the Shell Rotella pre-mix?<br><br>Bill
Re:Radiator Flush
Here is what i found out about Prestone Anti-Freeze.<br><br><br>Thank you for your inquiry and your interest in our products. The Prestone Antifreeze Coolant in the Yellow Jug<br>AF-777. Is not a Low Silicate Antifreeze. Yes, ideally a Low Silicate Heavy Duty formula is best for such Diesel<br>Applications. We do however make, Prestone Heavy Duty Antifreeze Coolant. This is a blend of ethylene glycol and<br>specially formulated inhibitor package designed for heavy-Duty applications. The product is designed to eliminate the<br>need for an initial charge of supplemental coolant additives on new vehicles and recharged systems. Can be used in all<br>heavy duty vehicle applications. We hope this has been helpful.<br>
Re:Radiator Flush
And here's what I posted in the other antifreeze thread.<br><br>Just visit your local Cummins outlet and get the Fleetguard 50/50 mix.<br><br>No questions.<br>No mixing.<br>No guessing.<br>Just the recommended coolant for our engines.<br><br>I'm sure it's a bit more expensive than off the shelf antifreeze, but why take chances.<br><br><br>phox
Re:Radiator Flush
Good idea on the flush for the radiator, but beware if you flush the block with that chemical there is a good chance you'll loose your water pump seals in a short ammount of time. Fleetguards stuff you know is good, it must be it's Cummins .
Re:Radiator Flush
How well do you know the history of your truck? If you do a flush, you could free up an old leak he plugged. If your not sure about the past, you may want to be sure you have funds available to replace parts in case of emergency.
Re:Radiator Flush
It was done yesterday. I got it flushed and a new T-stat. I about fell over when I saw what came out. We used a flush/fill machine so no air got in the sytem and it does a real good job of getting all the old crud out. I feel better knowing it has a nice new 50/50 mix in it. Bill
CACalomino
16
03-22-2010 06:35 PM
Sam Turner2
11-18-2008 10:17 AM
