R134a Conversion
Single 12oz cans are around 450 pesos, about 35 bucks. I have a very old slow leak in my system and I take it to the same shop in Hermosillo every couple of years and the last time cost 700 pesos for less than 12 oz, installed. I noticed that they were using dow r12 and asked about the propane replacements like frigic and they told me that they had been banned in Mexico. They also told me that there was a shortage of r12, all that was last summer. I am going back in a couple of days and I'll check and report back..,.Mark
Also, R12 is contraband at the border, which might add to the cost ..Mark
There are 30lb cans of US freon for a lot less here.Last sealed can I bought was $300.00 DuPont.Do not buy the stuff made in India!!!
Even Better....
http://hdsupplysolutions.com/shop/pr...t_r414b-150101
25 LB HOTSHOT REFRIGERANT R414B
HD Supply Part #: 150101
HotShot Refrigerant R-414B 25 Lb Cylinder - Direct Replacement For R-12, R-134A And R-500 - Does Not Require Oil Change Or Mixing -Does Not Require Component Change - Compatible With Mineral, Alkyl Benzene, POE And PAG Oils - Do Not Mix Refrigerants $299.00
Product Details
HotShot Refrigerant R-414B 25 Lb Cylinder - Direct Replacement For R-12, R-134A And R-500 - Does Not Require Oil Change Or Mixing -Does Not Require Component Change - Compatible With Mineral, Alkyl Benzene, POE And PAG Oils - Do Not Mix Refrigerants - EPA Certification Required
Replaces R-12, R-500 and R-134a EPA/Snap accepted for use in both stationary and mobile systems Lowest cost conversion with least system modification No unnecessary oil changes are required Low, Medium and High TemperatureR-12 alternative
Product Documentation
MSDSMSDS
View the Material Safety Data Sheet (MSDS) for this item.
Make & Model
UNSPSC 27112801
Specifications
Country of Origin USA
Dimensions
Depth 10.20 in
Height 16.50 in
Weight 32.3 lbs
Width 10.00 in
Product Features
AbilityOne No
FOB No
Manufacturer Name JOHNSTONE SUPPLY CO
Supplier Product Name Hot Shot R-414B Refrigerant 25lbs
Wow $300.00 is a great price, do you know if it virgin or reclaimed?
I have also used Icor HotShot and the price has really jumped on that also.
Without a gas analyzer I am afraid to buy partial cylinders with the scam of people refilling it with 22 or cheaper gasses.
Jim
Jim
I have also used Igor HotShot and the price has really jumped on that also.
Jim
Jim
The 30lb can I bought was "sealed" DuPont,fresh,nos.I think that in the future I will switch over to "the blue can" R-4148.Did you do a flush and re-fill or just add the 4148?Does it perform as well as the R-12?
Today on Craigslist,Las Vegas
New Jug of R-12 and R-134a 30Lbs $400 (N. las vegas )
http://losangeles.craigslist.org/sfv...881936775.html
Refrigerant R-12 - $300 (Woodland Hills)
carrnutt
03-30-2011 07:01 PM
Superduty12v
22
10-11-2002 07:42 PM
