Quiet time
Old 08-16-2008, 07:58 AM
NotEnufGarage's Avatar
Quiet time
Here's a few pictures from my project to reduce heat and noise in the cab.
I taped foil back insulation to the back of the cab, below the window ;
Then some carpet from the local auto parts store ;
More insulation on the floor;
Put the tool tray back in;
And the trim below the window;
I also recovered the headliner, added insulation to the roof and doors and put in new seats. I'll upload the pictures of those when I get time to resize them.
Now, I'm off to cut up my fenders to add vents.
Old 08-16-2008, 08:04 AM
Free89W350's Avatar
Are you going to use the pocket knife behind the tray to cut the fenders for the vents.
Old 08-16-2008, 09:36 AM
Yeah.. And I'll use the red bottle to put out my cigarettes, too.
Old 08-16-2008, 10:09 AM
Diesel_Dawg's Avatar
What kind of speakers do you have in the back of the cab?
Old 08-16-2008, 10:48 AM
They're cheap $20 Roadmaster speakers from Kragen. 4"x6" 3-ways. I had to cut out the grilles in the brackets for them to fit, but they sound pretty good. Same speakers in the doors. (They were out of 6x9 when I picked them up - I may replace the door speakers at some point).
Old 08-17-2008, 05:26 AM
KRB
KRB's Avatar
Is that your Duster in the 2nd shot?
Old 08-17-2008, 06:27 AM
Yep... I'll try to post a better pic, if you like.
Old 08-17-2008, 06:41 AM
KRB
KRB's Avatar
Sure! My first car was a '76 Duster. Got totalled trwice before it finally died.
Was a "Space" Duster.
Old 08-26-2008, 12:08 AM
Okay. Finally got around to resizing the rest of the pictures...
Here's the headliner ;
And the new seats ;
It's much more comfortable than the old bench seat. The springs actually have some spring to them.
Old 08-26-2008, 05:57 AM
archer2's Avatar
Did you use that same foil backed insulation overhead and if so how was the fit with the headliner? Also, what did you use in the doors?
Old 08-26-2008, 07:14 AM
dumptruck200's Avatar
How much lower is the noise in your cab now?
Old 08-26-2008, 08:10 AM
I taped a piece of the foil backed insulation to the inside roof. It took a little pushing and pulling to get the headliner trim screws in, but not a lot of extra effort. I also taped some of it up behind the door panel in place of the missing plastic sheets. It sealed up well.
All in all, it's noticeably quieter. It's hard to quantify it, but it definitely an improvement. All the rattles and such are gone, but now wind noise is more noticeable. I'll have to replace the wing vent seals to take care of that. I'm also noticing some squeaks and rattles from the dash, but I don't have everything screwed down there yet.
Old 08-26-2008, 08:52 AM
unixcowboy's Avatar
This did more to lower in cab temps than running with the window open ....
Well, almost....
Old 08-26-2008, 10:12 AM
Last weekend I taped up the area where I want to put the vents, marked where to cut then got sidetracked on something else. I'm having a little difficulty cutting into my fenders after I just painted the truck!
Here's a pic of what I'm planning ;
with another one right in front of it (maybe).
Old 08-26-2008, 10:17 AM
BRUISER's Avatar
what is the reason?
just curious since my truck never got hot..
Quick Reply: Quiet time
