Quick Drain Oil Plugs
I WANT TO THROW THIS OUT FOR MY OWN RESEARCH. IS ANY ONE USING THE QUICK DRAIN OIL PLUGS? SOME BRAND NAMES THAT COME TO MIND IS FUMOTO ( spelling???) BW, AND A BRAND I SAW IN GENO'S CATALOG. HE USED TO CARRY THE FUMOTO BUT I DIDN'T SEE THEM. I HAVE A TWO WHEEL DRIVE CREWCAB CONVERSION AND JUST USE IT FOR DAILY DRIVING AND PULLING MY CAMPER. I AM LOOKING FOR OPINIONS , LIKE / DISLIKE ANY PROBLEMS. I DON'T WANT THIS TO TURN INTO A 5 PAGE DISCUSSION JUST SOME CONSUMER USE / EXPERIENCE, THANKS GUYS!!! AUGIEDOG
I'm not sure what brand name mine is, I got it from Genos it has the turn down so I can put a tube on it and then drain into a jug without any mess, it has the spring loaded lever. seems to be real handy and dosnt hang down to low. I had one on my old Toyota for years and loved it.
Genos plug
I've got mine from them. Love it. Very quick, hardly any mess, no issues with is bottoming out anywhere. Going to get one for my other CTD.
thumbs up here.
thumbs up here.
I put FUMOTOs on everything and love them, no drip, no oil running down my elbow, no fishing the drain-plug out of the catch-pan, no stripped threads, no mess, no wrench.
I catch the old oil in gallon-jugs via a small funnel; when a jug fills, I close the valve, switch jugs, and open the valve again.
A guy at the shop just removed the drain-plug from his vehicle one time too many; it cost him having to pull the pan and have the welding-shop weld in a new nut inside the oil-pan.
The guy that did the welding said he did at least one per week.
You say there is no clearance issues. What about driving through tall grass, brush, etc? Any chance that they will hang and open automatically? I've never had one so not familiar with exactly how they work and what can & can't happen.
By design, I don't think the Fumoto valve could open from driving in tall grass. It's a ballcock type valve that's spring loaded. You press it over an indention and then turn it. If it's a major concern, I would simply face the lever towards the back of the truck.
Some places that sell the FUMOTOs offer those springy-wire hose-clamp thingies as a safe-guard for those who worry that the valve might accidentally open, or be tampered with by some moron that would think it funny to watch all of your oil run out.
I don't see a FUMOTO being too easily opened by brush, tall grass, and the like, due to the need to unlock the handle against spring pressure and then turn down the valve.
To discourage idiots from messing with them, I use the little springy gizmos; I figure at least they would need a pair of pliers to open the valve.
I don't know what the outcome would be if one were to go to one of those quickie oil-change places with one of these valves; they would probably cut it off with a torch.
As far as clearance issues are concerned, someone at the trucking show was demonstrating the kind that requires a seperate drain-hose that must be threaded into the portion that remains in the oil-pan.
The valve that stays with the pan is no bigger than the head of the factory drain-plug, so clearance with that type should be no issue at all.
I used to have a link to them, but can't find it.
FRAM sells an almost identicle one.
When I was looking into it, the two-part hose type valves were selling for around $75, while the FUMOTOs were about $25.
The FUMOTOs are entirely self-contained, while the others require you to keep track of the special drain-hose, for without it, you aren't going to drain any oil out.
Also, the FUMOTOs can be turned on and off at will, while the hose-type are all or nothing.
Here is a link to the FUMOTO at Scheids :
http://www.scheiddiesel.com/fumoto_valve.htm
Not the spring-clip thingies I mentioned a while ago.
From their website:
"Warning: For users under extreme conditions
If you are using the engine oil drain on off-road conditions such as corn fields or brush areas, it is recommended that a hose clip, as shown below, be used for extra safety and security."
I like. Sounds like a good mod and the hose clip should remove any fear of unanticipated oil evacuation.
I've got the EZ Change drain plug http://www.genosgarage.com/prodinfo....Z-DP-22MMPL-DG.
The old plug was start to fragment. Since I've installed this, no more burnt hands or oil on tools, it just screws in and things are good. Well worth the money... (IMHO)
The oil filter is another story...
