Pyro not registering at low egt's
My autometer pyro does not register correctly at low egt's at an idle and stop and go traffic it barely moves off of 0 degrees. At 60 mph i am at only 400 degrees. I thought that is kinda low. After a long trip as soon as it goes to an idle the temps fall to 150 degree and then within a minute they go to zero. What wold make it act that way? thanks
Run a ground wire from the engine to the firewall and see if things improve. Our body grounding is often pretty poor after 15 years - and it wasn't the best to start with.
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
I just went fomr the firewall behind the #6 vavle cover to the bolt s on the intake manifold and it now jsut stops going down at 100 degree and wont go to zero anymore. So it helped out but wasnt exactly it.
I had a bouncing reading problem and I called autometer direct. They said to run a ground wire from the gauge directly to the negative terminal on the battery. Worked great.. I agree on the bad cab ground....
YOu know what else it could be is that if you shrink wraped the wires together running into the cab you will get a bonkers reading. Mine were interfering with each other because the 2 screws ended up touching each other. I just e taped them apart and re shrink wrapped.
Blessed
01-09-2004 05:02 PM
