pump question,do i have a weak pump?
Old 03-31-2009 | 05:49 PM
crewcabxlt's Avatar
ran 2 different pumps on same truck,identical set-up. one pump seems weak,makes about 4 lbs lees boost, both are non i/c pumps. the weak one had a bad ksb,on all the time. ive never been deeper in a pump than gov. spring install,would a part wear due to higher case pressure of ksb not working? what wears inside of pump when they fail? pump runs good,smooth,starts good,just weak on fuel. help appreciated
Old 03-31-2009 | 08:07 PM
Onemoparnut's Avatar
Could just be a difference in how they are tuned maybe.
Old 04-01-2009 | 09:45 AM
crewcabxlt's Avatar
both tuned the same, fuel screw turned to almost runaway,same afc set-up. looking for info on internal pump wear parts.
Old 04-03-2009 | 10:51 AM
79warlock's Avatar
I am also curious about pumps internally. I got some water in my fuel was passing right through the filter and didn't know it until the engine started missing(would have a dead hole every 5-10 seconds of running). Now I seem to be down on power and would like to know from the VE gurus if they can be tested, what would most likely wear out/be damaged from contaminated fuel, etc and can they be fixed.
Old 04-03-2009 | 06:31 PM
A pump shop can put it on the bench and test the flow rate.
The head & rotor assembly and the cam plate & rollers are the most vulnerable to dirt or poor lubrication.
dj_souvlaki
02-27-2008 06:46 PM
realsquash
02-05-2007 05:57 PM
FIRECAT7000
03-10-2006 07:58 PM
mopar2ya
08-26-2004 12:23 AM
crobtex
05-02-2004 07:35 PM
Quick Reply: pump question,do i have a weak pump?
