Pump Pouring Fuel
Pump Pouring Fuel
I haven't been on in a while, been busy. Went out and started the ole 92 up for the 1st time in 7 months. Put the charger on it and about 3 rolls and it busted off. Running like a champ. Letting it just run and warm up. About 10 minutes later I noticed fuel pouring from under the truck-hmmmm.
Raised hood and it's coming out from the little vent tube behind the afc. What's the fix? Any help appreciated!!!!
You need to reseal the small fuel pin that rides on your big one in the AFC. You can find the "how to" in "The sticky". Good write up there.
You need to remove the AFC to do this though. You will also need one of the Bosch DGK-121 reseal kits.
Just pulled the afc off. Trip to pump shop or Cummins. Never happens when ya don't need the truck does it!!!!!! 366 spring time also. Thanks for the input thrashingcows muchly appreciated.
ouchman
03-31-2004 02:10 AM
