Pump gear advance
Now I have to turn the pump back, went a little to far I think. 1 tooth plus 1/8th in and truck doesn't run smooth at speed and acts like it's trying harder. time to turn the pump back.
Maybe mine is messed up, I jumped a tooth and still have my pump up against the head and it runs great. Could be the new injectors pop high or something. Not sure yet. Boost is down about 5psi. Anyone know how much boost I should expect to loose jumping a tooth and not changing the pump settings?
1st Generation Admin
It's funny. If I advanced a tooth my mess would 'splod no doubt.
I've always done mine with the dial micrometer measuring actual pump lift. Stock, mine was at 1.4mm. When I advanced the typical 1/8" plus a bit, I found the timing at 2.10mm. It sounded as though it was trying too hard as np205 commented. I've since backed it down to 2.0mm and it runs very well.
With that, I've still got almost 1/4" between the pump and engine. Weird.
4969joes
03-27-2010 08:58 AM
pwrtripls1
06-06-2005 11:34 PM
