Pulled the donor engine
Got the engine and trans removed from the donor truck yesterday. Kind of a tight squeeze getting engine and trans out together but not too bad. Found that the pass side engine mount was seperated. No real problems though. Toughest part was the four bolts holding the carrier bearing bracket. Two of them broke off. That wore me out. Next is pull the 318 from the 1/2 ton. Lots of work to do.
