progress update: 9mm head, 500K+ miles... no cracks?!
Old 09-03-2009, 01:47 PM
  #136
crewcabxlt's Avatar
i feel you getting screwed a little, sounds like your getting stock pods for too much $$: anyway- keep us posted
Old 09-03-2009, 01:51 PM
  #137
jimbo486's Avatar
maybe so. but these will absolutely have the correct spray angle. before i could say anything about spray angle and whatnot, the guy's were taking the words right out of my mouth. they're very knowledgeable having done this many times over.
Old 09-03-2009, 01:54 PM
  #138
crewcabxlt's Avatar
ok, suonds like they should be good.
Old 09-03-2009, 03:14 PM
  #139
bgilbert's Avatar
I suggest you have them set the pop pressures to stock, 245 bar. You'll make more power that way and the injection pump won't have to work as hard.
Old 09-03-2009, 03:22 PM
  #140
jimbo486's Avatar
can you elaborate on how a lower popping pressure would make more power? i don't know much about injectors, but it almost doesn't make sense to me.
Old 09-03-2009, 03:36 PM
  #141
crewcabxlt's Avatar
260 bar will be harder on the pump,some have run pods a long time with no issues but if you have a choice go 245. if you stay w/260 bar you have advance timing more to compensate for slightly retarded timing from higher pop. if you get injectors and bodies say lucas delphi you got pods.
Old 09-03-2009, 03:59 PM
  #142
jimbo486's Avatar
the technician told me that raising the popping pressure will have no effect on the the performance of the pump. i found info somewhere that said the VE's put out about 17,000psi. the pump effects the injectors. the injectors don't effect the pump. the injectors are only for metering and atomizing and they'll only put out what the pump gives them. he said it would be like running the stock injectors again and therefore pointless if they set the popping pressure back to 245. although, he did say that i may have to advance my timing slightly.
Old 09-03-2009, 04:05 PM
  #143
Uh, the VE runs about a tenth of that.
Higher pop pressure will work the pump harder, it puts more stress on the cam plate and rollers. The pump puts out enough pressure to work the injectors that are connected to it, if that makes more sense.
Old 09-03-2009, 04:13 PM
  #144
jimbo486's Avatar
it does make sense. just other words for what i said as far as the pump effecting the injectors, it makes them work. so then what could result from higher pop pressure and a harder working pump? a shorter pump life would be my first guess.
Old 09-03-2009, 04:17 PM
  #145
bgilbert's Avatar
Sounds like you've got a good shop there. Try what they give you and report back to us.
  #146
Yep. And it retards the timing. There's nothing good that happens to offset the negatives.
Old 09-03-2009, 04:28 PM
  #147
jimbo486's Avatar
good information! thanks bgilbert, dave and crewcab! i'm glad i have places like this to go to. i won't lose any performance out of them setting them back to 245 will i?
Old 09-03-2009, 04:30 PM
  #148
apwatson50's Avatar
I gotta say it sounds like you're getting POD's, expensive POD's
Old 09-03-2009, 04:39 PM
  #149
366 Spring Chicken
Richie O's Avatar
With them saying 260 bar I tend to agree.
Old 09-03-2009, 04:44 PM
  #150
366 Spring Chicken
Richie O's Avatar
I do have 1 question. I read back in the thread a little and he says they are using his 9 mm bodies and changing the tips to 4x14's. I thought that the lucas injector parts were not interchangable? Maybe he is getting what he thinks.
Quick Reply: progress update: 9mm head, 500K+ miles... no cracks?!
