pot inplace of tps
pot inplace of tps
I read what was in the sticky sbout it and just wanted to make sure on a couple of things. The main thing is when you replace the tps with a pot does your cruise control still work? I also was looking at the switch idea and wondered if I left the tps in, could I plumb in a od switch to turn on od at any time, or do I need something else to make the switch work.
Thanks,
Owen
Thanks,
Owen
Yes, the cruise will still work.
If you install a mystery switch, everything will work as normal except when you flip the switch. All you're doing is grounding the OD circuit.
