possibly a stupid question
I've never used it for that, but it's not made for high pressure if thats an issue and i dont think it's very smooth inside if you look at it very close and i dont think it has any sort of coating on it so that may cause you some problems, alot of if's. I would try to find the right pipe for the job my if it were me. good luck.
Turbos don't even come close to what I would consider high pressure, as most will make a maximum of 30-35 PSI.
So long as the design is good and you clean up all welding beads/slag, not allowing anything foreign to enter the intake, I say go for it.
The worst that could happen is to make a bulge in the tubing.
BUT, I am not at all familiar with "water sprinkler pipe", so if you mess up something, you are on your own.
sorry for bring unclear. yes i meant replacintg the oem crossover with two rubber 45 degree elbows and piece of alluminum pipe. the wall of the pipe is probably 1/16 inch thick .
mysterystench
09-19-2006 06:42 PM
mkinla
18
01-09-2006 10:26 PM
