possibly my master cylinder gone bad?
hello, well i just got home from driving for a couple hours and when i went to park my truck in the drive way i pushed the brake and then applied force and the brake pedal sank to the floor not quickly though, could this mean my master cylinder is beginning to go? or possibly i have a bubble in one of my rubber brake lines? there is no brake fluid what so ever under the truck and i never had this happen before and the brakes work fine, any suggestions?
The symptom you described sounds like a master cylinder going south. The seals are notorious for leaking internally and it's accredited to the heat that the diesel engine emits. A bad caliper would cause the same symptom but I would look into the master first.
Location: anderson commiefornia oh ya you can keep the "change"
I have had new and rebuilt masters go bad. Side note, since its losing fluid this may not apply to you but when mine had similar symptoms the rwal unit failed. bypassed it and had perfect pedal... you wouldnt believe me if i told you how many times i bled that system... good luck!!! ps napa rebuilt mc was the one that finally worked for me.
Good that you had mentioned that. Mullishacrew, does your RWAL system work? If that dump valve is bad, it will have that same feeling at the pedal. Bypassing it is easy and the parts are available from NAPA or other parts store. Some here will argue to leave it be if it works while others have had problems and bypassed the system to avoid the 300 some odd dollars for a reman unit.
Anyone ever see a dumpvalve go bad in this manor and not throw an ABS code ?
Im having similar issues, but no ABS light. I may just need to keep doing the reman shuffle.
dirtydog
08-07-2011 08:09 AM
Gen414
05-07-2009 11:08 AM
cgmorgan06
11-15-2007 04:02 PM
