Port matching turbo housing to manifold
Hey guys goin to grab that whic tonite now I've heard a lot about port matching them[me thinks mostly from Wannadiesel] anyway what does this gain /how much is too much/ do i cope the new gasket some or use it as template tks Eric
I made an outline of the gasket on the 12cm flange with my trusty Sharpie, then used a die grinder to open the housing up to the sharpie lines. Then I just tried to make the transition as smooth as I could without removing a bunch of material. An inexperienced hand (like me) can do a lot more damage than good when porting, so I took it easy. I definitely noticed a difference in spool up, though, so I didn't do all bad
Patron Saint of 1st gens
What you're doing is helping the exhaust gases to exit the head/manifold and enter the exhaust housing faster. This is a benefit and about the only thing you need to watch is that you don't over do the smoothing of the exhaust housing inlet walls and don't touch the center web.
pb...
pb...
Hey guys thanks for the replies. since i'm buying a new gasket I'll used the old one as a template held on to each part with stove bolts. This being patience and doin bombs in logical order is killing me
1985cucv
05-22-2009 03:01 PM
cquestad
03-03-2009 12:55 PM
QWKRTNU
09-26-2006 10:22 PM
