Pop tested my injectors
I took my injectors out last night, soaked them in some DK, brushed the chunks off them this morning and took the to Imler Diesel to be tested. 5 of the 6 were right on at 245 Bar, but the 6th wouldn't build pressure at all, so I'm thinking this, along with the stuck fuel pin were the cause of my high temps and hazing/smoke clouds.
Picking up a new (rebuilt) injector from Diamond Diesel tomorrow ($65 exchange) and should have her running again tomorrow night. It should be interesting to see if I can tell the difference with all 6 cylinders fueling correctly.
I can't wait!
I can't wait!
Diamond Diesel is a great place. I was there yesterday in fact buying some stanadyne.
Next up will be the 56mm compressor that PapeCat gave me today. That should provide enough air to allow for some more turns on the full fuel screw!
Maybe my next run to Montana will be at 95MPH instead of 85MPH?
Tom
Here is the fuel additive test results we spoke about today.
http://www.johnfjensen.com/Diesel_fu...itive_test.pdf
You'll see that the cheaper per tank Stanadyne lubricity formula performs better than the more expensive performance blend.. Interesting study though...
Tom
What bothers me about it is that the amounts of used motor oil and 2 cycle oil they use is so low. I use 12 times or more of WMO from what that study did, so the difference has to be much more signifigant.
Is it running smoother. vids?
Just as Cummins intended...
The test will be Saturday when I take her down to Infineon Raceway for Mopars North of the Gate and Baconfest 2009.... Maybe I'll take her out on the track!!!
SO5.9
01-25-2009 08:07 AM
