pods betters the non i/c sticks??
Old 06-17-2010 | 01:26 AM
1stgen lover90's Avatar
Was just looking around for so no sticks and was just woundering if pods are better than non I/c sticks
Old 06-17-2010 | 04:11 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
From experiance I would not buy them again, I had a set in my truck for a while then pulled em out and sold em and put the stockers back in. Use the money you would spendon those and get a real set of injectors or do other mods with it.
Old 06-17-2010 | 11:55 AM
So I should save up a lil longer and buy some 6x.016 for a real HP gain
Old 06-17-2010 | 03:44 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
It depends on what you are going to do. 5x14's will make some big power and are streetable. I see some guys say they need to use some real skill to keep the smoke to a minimum with 6x.016's.
Old 06-17-2010 | 06:28 PM
big stinky's Avatar
I didnt mind my pods, they were just a bit hazy... Had to have lots of timing for them to be happy in my engine. The non i/c injectors are pretty hazy when the timing is up there too, but when the timing is conservative, the stocks are clean.
POD's were worth a bit of seat of the pants power as well.
As far as 6x16s, they are dirtier than the pods. Or at least all the videos i've seen of them.
The pod spray pattern isnt that far off with non i/c pistons, see my gallery for proof.
Old 06-17-2010 | 08:13 PM
jimbo486's Avatar
i have 4x.014 nozzles but they're not PODs. with my pump in stock form back in september, they made more power (referencing the boost gauge) than the stock injectors (4x.012)
Old 06-17-2010 | 08:24 PM
Big stinky Are u still running your pods or do u have different sticks now and arnt non I/c sticks good tell 400 HP or so??
Old 06-17-2010 | 11:08 PM
crewcabxlt's Avatar
i ran pods and non i/c sticks,switched and tested. as stated pods clearly made a little more power. i like them for cheap power. they do work well with non i/c pistons. however if your current injectors are fine spend your money elsewere.
Old 06-18-2010 | 12:31 AM
big stinky's Avatar
My dyno numbers are with stock injectors. I think it depends on the dyno, but from numbers off the dyno I ran, and comparison to other 1/4 mile times from vehicles run off that dyno, I think that 400 hp off stock non i/c injectors is possible.
Old 06-18-2010 | 12:37 AM
But is your truck a manual
Old 06-18-2010 | 12:52 AM
big stinky's Avatar
yes
Old 06-18-2010 | 12:56 AM
Well i am in a lil different situation do to the fact I got a first Gen motor in a second Gen everything else but I got the 47rh that's that's a plus once I can afford to have built so maybe wont loose that much HP cuz I have lock up
Old 06-18-2010 | 03:07 AM
W150CTDproject's Avatar
my stockers are hazy just like my friends PODS in his i/c truck. then again my timing is cranked to the head and his is about half of my timing. i wouldnt get pods if u have a non i/c motor. some 5X14's i hear are perfect for a daily driver
Old 06-18-2010 | 09:19 PM
92smokin blacky's Avatar
I've loved my PODs, for $315 I couldn't be more happy with them. Although I have a i/c truck, I've really liked them and they do make decent power. But if i did have a non/ic truck I probably wouldn't get them since they are just a hair bigger than the stock ones. Like the others said, spend your money on other performance parts or on some bigger injectors. I plan to get some 6x18s someday and sell my PODs once I get some other stuff done first.
DNRCustoms
05-31-2010 08:53 PM
Garz
06-02-2005 06:40 PM
Garz
02-18-2003 11:07 PM
TIM-D-FARMER
01-06-2003 09:32 PM
