pods
pods
i was wondering if anyone knew what size O ring i need to put in between the retaining nut and the body......i just got those pods and my number 6 injector is leaking ....needs a new o ring...so if someone could help me out and tell me what size to get that would be great
i had joe call up piers where he got the injectors and they said to make sure the bore hole is 100% clean....and i really did do that....so i will do that again.......and see what happens ...thanks dave
SmokemS talked to an injection service station and they said the injector body could be cracked. Piers contradicted that saying they never heard such a thing. If that could happen what would cuase it at such low milage on them?
Josh also mentioned to me that the copper washer on the leaking injector does not stay stuck to it when we pull it out unlike all the others. I dont know if that will have anything to do with it. but i figured i'll throw it out there. I would like to get these things to stop leaking for him.
The tip sealing surface really needs to be clean for it to seal. Torque the nut to 44ft-lbs and make sure it's not the fuel return banjo bolt washer leaking or the high pressure line. After torqueing the injector nut is it tight in the head or still loose? Some heads are cut differently and some injectors don't fit too well, especially with the .020 washers.
well guys i went to install the injectors again and the number injector line nut stripped on me........do i have to get a new line to put on or do i have to buy all new 6 lines?......i'm really having trouble here ....i'm almost at the point of just gettin rid of the ol girl....is there any easy fix for the nut can i some how replace the nut or do i have to go threw and get new lines?
Josh. You will only have to buy the single injector line that got stripped. I replaced mine when they were leaking at the pump head and got them all individually. Bgilbert has a good idea about the bore brush.
ok guys ....i bought the new injector line today 95 bucks shipped to me over night.........put the line on (easy as pie)....and the same injector that was leaking before started to leak again.........now i'm gonna call up piers tomorrow and see if they will do something about it......give me a new one and i'll send back the bad one....if not hopefully SOMEONE will make good for it .......i'm running out of options i dont wanna give them up ...... now for my next question....can i buy a seperate pod injector?
Did you clean the bore real good this time, use a new sealing washer, use a new copper horseshoe washer, torque the hold down nut to 44ftlbs, and was the injector body TIGHT in the head? Just some questions Mark is gonna ask you.
If you did all that properly, you might get all 6 injectors pop tested and be sure to mark the pesky leaker to see if it's not popping correctly.
jec3
50
03-23-2003 10:00 AM
FireNhole
02-25-2003 11:22 AM
Mopar_Mudder
11-16-2002 01:30 PM
