plumbing question
plumbing question
I'm going to be installing a fuel heater on my 92' .Does any body know which ports are the presure side and which are the suction side?
thanks
thanks
Sort of. but there are numerous ports around the engine I'd like mto use.I'd rather keep the lines for the cab heat seperate.I'm know aboat the one above the filter.thanks
The port right next to where the top heater hose comes out is also pressure. For suction you'll need to tee in where the heater connects to the elbow from the lower radiator hose.
P.J
10-28-2006 01:07 PM
