Piston Pump Spacer
Piston Pump Spacer
When using the 2nd Gen lift pump do I still need that spacer used on the low press. piston pump? And what is the thickness of that spacer might be able to make one as to buying one? Converting to P-pump and just going to use the 2nd gen pump untill I get money then ordering the Airdog.
I do not have it in front of me, but I would say it is 1/4 inch thick. I just installed one two days ago.
The spacer itself is certainly not 3/8 inch thick.
It may be 3/8 inch thick if you include both gaskets that are required to go on it.
Russ
Russ
