piston pump 3933254 low pressure?
I bought this pump used, it is from a 4bt with an A pump. I took it apart and it has the bushing/small piston and the conical spring. You think it would be OK to run? I know it is not one of the common low pressure pump part #s, but seeing as how it has the right parts inside, what do you think?
Bill, I had to rob the one from the 84 to put on the work truck, as its diaphram pump finally bit the dust. I picked up this used one hoping to go to the dragstrip again this year.
