Piston lift pump what a difference
Originally Posted by hertz
After installing the piston lift pump we finally got to run it. It ran really good. Running out the PA. turnpike never when below 65mph up the mountains. I guess the old pump was a turd. Now I have to get the injector pump rebuilt or replaced. Hopefully it will be a really good running truck.I can't believe the difference. Old pump we would only run 45-50mph up the mountains have to shift out of 5th. Thanks for all the good info on here
We checked all the connections all good. It seems that we are slowly losing boost and picking up more smoke (haze). When you driving down the highway at night every once and awhile you see a puff of smoke. everything else has been replaced except for the IP so that is why I think it is the problem. Here what I replaced injectors,all the injector lines, lift pump, all the boost hoses,turbo,head rebuilt, arp head studs, anything that we thought might be an issue was replaced.
Now for the next step. What do you think I should do Reman, Rebuild or New. I was thinking on sending it to Scheid Diesel and having them give me there honest opinion. Sending the IP and injectors to make sure everything is clean and the BAR is set properly.
I've heard nothing but good things about them. Make sure you tell them that this is a working medium duty truck, not a pickup. They can't get as aggressive with the pop pressures and the fuel delivery without compromising pump life.
yamarx1
02-13-2009 10:37 AM
