Piston lift pump what a difference
Old 06-25-2006, 01:07 PM
hertz's Avatar
Smile Piston lift pump what a difference
After installing the piston lift pump we finally got to run it. It ran really good. Running out the PA. turnpike never when below 65mph up the mountains. I guess the old pump was a turd. Now I have to get the injector pump rebuilt or replaced. Hopefully it will be a really good running truck.I can't believe the difference. Old pump we would only run 45-50mph up the mountains have to shift out of 5th. Thanks for all the good info on here
Old 06-25-2006, 01:29 PM
92DIESEL's Avatar
Congrats, its alot to push a barn door through the wind uphill with speed, and your getting there! Good luck on the pump- BTW where are you getting it from.
Michael
Old 06-25-2006, 01:39 PM
BearKiller's Avatar
My truck runs like a scalded dog, as it is, with a stock (the original) lift-pump.
Is the piston lift-pump worth the trouble/expense, should my pump ever need replacing??
Old 06-25-2006, 01:50 PM
hertz's Avatar
I get all my parts from Bayshore Ford, Newark DE. they are a cummins shop. It can't hurt if cummins thinks it's good for our motors. That is really the only reason I got it (Cummins part). We travel such long distance I need a reliable truck.
Old 06-25-2006, 02:24 PM
Ace
Ace's Avatar
I too would like to know the deal on this piston lift pump. Why is it better and where's a good place to get it, online preferably?
Old 06-25-2006, 02:38 PM
hertz's Avatar
I know it supplies more pressure to the injection pump versues the old style pump. My injection pump was probably starving for fuel before.No one has had any problems so far that I know of. Those big HP guys run FASS and other high PSI pumps to get a bunch of fuel to the VE pump. I don't need that I want good reliable HP. I want my truck to be a clean running truck (not alot of smoke) when banging though the gear and at WOT. Also I don't want to have to watch the EGTs on every hill! This truck probably weighs over 20,000lbs. Positive fuel pressure to the VE keeps it happy and cool
Old 06-25-2006, 07:29 PM
Check the sticky, guys.
I'm glad to hear the piston pump helped out. I've seen that truck and I think 20k is a very light guesstimate on the weight. I'd put it right around 30k loaded. A heavy load for that poor little 6BTA.
What's the issue with the IP?
Old 06-25-2006, 09:50 PM
hertz's Avatar
The IP seems to be a little weak, not making enough boost. Running 25 psi w/ the fuel screw all the way in. I think w/ a rebuilt or new pump I would be well into the 30s and have cooler EGTs.
Old 06-25-2006, 10:20 PM
flashgordon's Avatar
before you replace the inj pump check the turbo intercooler and piping for boost leaks. it don't take much of one to lower your boost pressures.
Old 06-26-2006, 08:09 AM
Ace
Ace's Avatar
.......Huh?.......
Old 06-26-2006, 08:45 AM
Originally Posted by Ace
.......Huh?.......
the tech artices at the top of the post page (how do i "Look here first")
lots of grate help full articles and theres one on converting our stock lift pump to a piston pump!!!
Old 06-26-2006, 09:10 AM
Ace
Ace's Avatar
Yeah I saw that before, but my question is why would I want to do that?
Old 06-26-2006, 10:12 AM
hertz's Avatar
We checked all the connections all good. It seems that we are slowly losing boost and picking up more smoke (haze). When you driving down the highway at night every once and awhile you see a puff of smoke. everything else has been replaced except for the IP so that is why I think it is the problem. Here what I replaced injectors,all the injector lines, lift pump, all the boost hoses,turbo,head rebuilt, arp head studs, anything that we thought might be an issue was replaced.
Old 06-26-2006, 11:17 AM
92DIESEL's Avatar
Have you checked the intercooler for leaks?
Just want you to check everything before spending money to find out it's something else
Michael
Old 06-26-2006, 01:28 PM
hertz's Avatar
everything was checked for leaks. we plugged the turbo and the intake pressurized it, attached a air pressure guage to it to see it we had any leakdown. we found none.
Quick Reply: Piston lift pump what a difference
