piller gauge mount
Old 11-23-2008 | 09:13 PM
thumbs's Avatar
piller gauge mount
Where can I get a piller gauge mount for my 92? Also do they just clip over the original plastic or do you have to cut? How do they mount?
thanks
Old 11-23-2008 | 09:24 PM
DNRCustoms's Avatar
I just picked a auto meter one up, they have them 4 sale in the dtr store... It has little clips that attach it to the factory pillar.. I used one screw in top instead and a clip push lock deal on the bottom and mine seems to be pretty secure..
Old 11-23-2008 | 09:29 PM
Montana2x2's Avatar
Goes over the plastic trim but I drilled a hole in mine to run wires etc. out of sight.
Old 11-23-2008 | 09:30 PM
thumbs's Avatar
Thanks what size gauge will they fit? I am gettin a 2 1/16 gauge. Will the mount work with that size gauge?
thanks
Old 11-23-2008 | 09:32 PM
1979-5.9's Avatar
Do you think that would fit in a 1979 truck?
Old 11-23-2008 | 11:25 PM
DU.DP.'s Avatar
the DTR site has them here or try genos garage http://www.genosgarage.com they also have a colum mount that clips over from what ive read here on the forum. it says its for the 94-98 years.
Old 11-24-2008 | 08:21 AM
thanks
Yes, they are set up for 2 1/16" gauges.
Old 11-24-2008 | 08:22 AM
If it has plastic trim over the pillar, yes.
Old 11-24-2008 | 05:31 PM
The steering column pod is listed for 94-98 but it works on 91-93 first gens.
Old 11-24-2008 | 05:47 PM
peobryant's Avatar
I've also seen them on '89 and '90 models. There is just a hole where the tilt lever should be.
98silver12v
10-07-2007 11:18 PM
raw122
05-30-2007 08:06 AM
badcompany
08-20-2006 09:00 PM
03CTDCO
06-13-2005 10:10 AM
ckennedy
10-18-2004 04:29 PM
