pictures of valvebody
just wondering if there was any pictures of stock valvebody parts pictures like mech. pictures diagrams any thing i found parts in pan from it spring and bearing trying to find out what and where they go
This is the best I can do for ya . . . .
It should cover you for the basic springs, and check ball stuff. (From a TransGo kit).
The thing I was talking about in your other thread was that in step 3. In my case, the Rooster Comb got loose on it's shaft letting the ball and spring pop out of place. It's job is to locate (by detent) the manual gear shift valve.
Hope this helps.
Hope this helps.
Originally Posted by keithplacervill
thanks for info what would be the best transgo kit to use on my trans part number
Fits: 1966~96 Chrysler Torqueflite and Loadflite rear drive and 4WD three speed transmissions, and 1988~2003 4 speeds. Including inline 6 cyl, V6, V8, V10 & Diesel; models 904, 998, 999, TC6, TF6, TF8, 727, 32RH, 500 and 518 42-44-45-46-47RH & RE.
Short firm shifts.
Holds 1st, 2nd, and 3rd to any RPM.
Backshifts to any gear you want (when Shift Command option is installed).
Compatible/configurable with 89% & 91% TQ's.
Short firm shifts.
I like it. Shifts quickly and firmly without banging. Negligible gear overlap with fast engagement when shifting.
sorry for 50 questions but was that the tfod-jr $19.00 or tfod 3 $80.00 or tfod -hd? $120.00 i think that was the opp. i had with that pre letters so was it 20 80 120 dollars
This is the model at Transgo ~ http://www.transgo.com/chryslerauto.html
It seems the latest Summit part no is ~ TRG-TFOD They show an earlier part no, but it's no longer carried, and points you to the TRG-TFOD.
Look it up here ~ http://store.summitracing.com/
NOTE: The picture they show is not accurate as there are a lot more parts. Those pics I posted above are from the kit I'm pointing you to. It's a much bigger box.
I imagine the one with the suffix "-hd" must be some heavy duty version or it's got some additional stuff. Dunno.
bryceepoo
16
04-30-2006 01:58 AM
Leon441
0
01-13-2006 08:17 PM
