PCM regulated charging question
My stupid Ramcharger is still driving me nuts ( OK, the Chrysler wiring is ). I have verified the Alt. is good, swapped another one anyway, traced wiring back to the PCM, and other than doing tests such as the carbon pile load test ( don't have one ), done everything that I can think of to make this stupid thing charge.
Thinking back to the last time I was playing with it, I had 12.05 volts at the batt lead ( obviously battery was discharged somewhat ) and 11.45 V at BOTH the 12V feed and sense lines at the alt. Now, I remember reading that sense should be lower than the 12V feed.
What could cause the voltages to be equal?
I swear I am about ready to throw a external regulator on this thing and yank the check engine bulb.
1st question. Do you have low voltage or no voltage out of the alternator with the engine running?
Definitely no charging Cougar, voltage at the Bat terminal of the Alt is 12.05 and drops with time, it is roughly 1/2 volt higher than the field and sense though.
Thrashing, this is on my Gasser 90 RC, it has the PCM regulated charging the same as the 92/93 diesel setup though.
I guess my main question is, if the voltage feed from the ignition switch is the same voltage as the PCM, not charging would make sense, the way I understand it's operation, it tries to charge to get the error ( difference ) between the 2 as close to zero. If that is the case, it is working perfectly, and the real issue is what is allowing the 2 voltages to be the same?
Does that make sense?
If you have 12 V on both field terminals, then the regulator (PCM if stock) isn't working or the connection between the PCM and the alternator is broken somewhere.
12 v is supplied to the alternator field. The PCM grounds the second terminal to make field current flow. If the second terminal is at 12 v, then it's not being driven to ground.
It's pretty simple to trace. If you check the terminal on the pcm and it's at 12V, then the PCM is not running or is bad.
On the not running, what else doesn't work?
Thank you all!
I don't know why I still keep approaching this thing with my GM thought process, but I do.
PCM grounding makes perfect sense now, I shall attack the ground side instead of the 12V side...... I do have a spare PCM so I might also throw that at it to check.
Ok, to bring this one to a close.
Grounded the green, had immediate full field charging. So, I wrung out the wiring, and for the life of me, could not find a THING wrong with it.
Changed the PCM, voila!
I just find it ironic that the guy here who always posts that 99 percent of the time, your problem isn't the PCM gets bit by a bad PCM.......
Oh well, if ya can't laugh at yourself.....
vwjunkie53
11-13-2008 09:51 PM
atc250r
10-03-2003 11:43 AM
