Pat
Pat
Been reading here for awhile. I have a 93 2 wd 350 dually auto
I have put in the gauges (boost, Pyro & trans Temp)( isspro tack I can't get to work), air filter and ordered a 16 cfm housing yesterday. I use the truck mostly for towing a 4 horse gn in the mountians of southeren BC (Nelson area), WHAT IS NEXT, it has been suggested 190 inject. ??? I have to redo my auto trans. also????? I need a schedule, Ha Ha
Start tweatkin the pump. there is good info for that in the the tech facts section of this site. 190s would be good injectors for towing. PODs are a good bang for your buck injector, but they are not as clean buring as the 190, but PODS do have mroe power potental if you dont mind a some smoke. I would start with the pump tweaks, then some injectors if you are still lookin for some more power.
More Advice Needed
What are PODS????What are 190's Also I have to pull the turbo apart any advice on how??? Grey hound just called it is here. Peers told me that I have over 200,000 K so I should change my injectors???? I will check out the pump stuff, but am a little afraid to go there???
Thanks
Thanks
HP Numbers
Hey Manganos:
What Hp numbers are you seeing with your setup?
I'm in the same boat as Pat; after reading, checking and sending some pms to members on this site and TDR, it appears there is only one true and tried way to wake up these beasts.
I'm waiting for Grey Hound to call with my shipment as well. I've ordered the Isspro gauges, HX35 turbo with a 16cm housing, 3200 GSK, Borgeson shaft, PODs, AFE Air intake setup..........I think most everyone running a 1st gen is utilizing this set-up. I guess if it ain't broke don't fix it. Shied away from the fuel pin might try to modify that puppy myself.
Buying the DTT stuff to beef up the 518.
Pat,
Give Piers Diesel Research a call they will be able to answer your question and can supply you with the parts that are needed. They are located in Surrey, B.C.
http://www.piersdiesel.com/
Al
Al
Maybe its just me, but I didn't see the 3200 gov. spring mentioned.
Here's 2 dyno plots overlayed with and without the 3200 gov. sping. Made a huge difference towing our gooseneck.
I'd recommend sticking with 190's for a tow rig. The POD's are fuel pigs, plus the EGT problems from the POD's require a lot more timing advance than I'd like to see on a working truck. The 190's are a much more efficient injector. POD's are for play trucks.
Aaaaahhhh
Wannadiesel............... now you've ruined it. Here I thought I was making the right decision by ordering the POD injectors!!!!!!!!!!!! Did I screw up?????
The truck will be towing but not all of the time and when it's towing it is usually a single car hauler.
Turbo is in
OK the turbo is in 16c the old one was 18.5. Took it for a quick test drive, seems like it is a little quicker out of the hole. Boost goes quick to about 12 and then climbs to around 18, no load just empty truck.
Still can't get the tack to work??? Now that is done What is next???
Should I order the 190's????
Grind the AFC lever inside the pump when you put in the 3200 spring. and bump the timing a little. You'll see 25-30lbs of boost. good luck and keep asking questions
before i got the injector i think i would make some adjustments to the fuel screw and the afc because that is free. Then if more power is still wanted i would order the 190
Since you're working it regularly, ignore Michael's comment about grinding the AFC lever. Makes 'em run too toasty (and smoky) on the bottom end with a load.
pump questions
I have to pull a big hill here it is 20 miles up and 20 miles down, with grades of 6 to 8 % so I don't want alot of heat I am thinking???
Right. Keep the EGT under 1200 while working the hill, and keep the engine wound up (over 2000 RPM) by downshifting if needed. RPM is your friend, especially with an automatic. The torque converter dumps less heat into the ATF at high RPM due to less slippage. High trans temps drive up the coolant temp because of the heat exchanger. At high RPM EGT's are lower due to more airflow and less load. More RPM is a good thing all the way around.
mdurbahn
11-17-2008 07:30 AM
